Subwoofer jumpers with electrical tape
Golitan11
Why the need for electrical tape? Just strip them to the length needed and put them in the terminal. Having bare wire sticking out doesn't gain you much
Ahh gotcha
What you do in that case is get a box cutter or some wire strippers, trim a fair bit of strands off the wire, then twist them together and it will fit.
Or you can use a small distribution block. Or throw some ring terminals on the wire, attach the terminals to a bolt on the inside of the box, and wire the same bolt on the outside of the box :)
Those jumpers only get half the current of the wire between the sub and amp, and they are very short (only applies to parallel wiring like your pic. A series jumper would have the same current as the positive and negative)..
Smaller wire is fine there if you redo it.
12 ga to the sub, 16 ga between terminals.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
if my wire's too big for the terminals, i usually solder the wires together, make a big solid chunk of metal, and use pliers and a hammer to kind of "condense" and "pack" the size smaller and circular so they fit, works majority of the time. i made two 10 AWG wires soldered look like a sinlge 12 AWG. thats what i usually do. i always use SHCA 12 AWG so it works great anyway. i've even seen people use dual input lookin things like they use on amps but for the terminals.
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
  • Who's Online   0 Members, 0 Anonymous, 492 Guests (See full list)
