Havoc 12s Box
g2shuck
I will post up my skecthup of the new design after work tonight anf you can let me know if there is any improvements you would make
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Here ya go.
5867cfa2-dce8-4f71-898c-89d6dcb3cf8b_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Move the port to the middle. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I was going to so center port but was not sure how to figure the lent her of the port legs when it hit the back of the box and split to each side. The port leg on the back wall now is 22.5 long do I just make each seperate leg 11.25 if I do a t port in the center? Also how to figure common wall then? It would be one common 3 common wall on back of the port but only 2 common wall on the center part. Torres cannot calculate for that
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
double post dang phone
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
its 2 common walls.
Yes, each side would be half the length of the single port. HOWEVER, the width of the port will be half once you turn the corner. SO, the initial port pieces will be a tad longer.
SMD Super Seller
My Feedback Thread
  • Who's Online   1 Member, 0 Anonymous, 778 Guests (See full list)
