Havoc 12s Box
g2shuck
Its not confusing, just take your time to find the numbers, then add them.
The advantage is the subs will load equally. With the side port, the subs may react differently from one another, due to their placement in regards to the port opening inside the box. One is closer than the other, get it?
SMD Super Seller
My Feedback Thread
thanks that makes perfect sense. before i have always used aeroports but wanted more port per foot this time
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
No - you wanted the correct amount if port for the sub you are using.
Port area is not determine by box volume.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Right but with aeros I was coming up with around 9 port per foot which I dealt was too low. I did some searching and could not really find an answer on how much port the havocs liked but I figured 17.45 for two was way better than 9 for two. If that is not right please let me know.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
What I was trying to say is that you have 35 sqin per sub. Does not matter how much you have per cuft.
If you have that sub in 1.5 cuft or 3 cuft, they still work great with 35 sqin of port area.
Current system:
Previous systems:
Ok sweet. This is why I like this forum you guys actually explain stuff instead of calling people noobs and insulting them Here is the torres on the final port setup you guys just helped me with above.
6c6ce104-752f-4766-90ea-cc741bd20001_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
  • Who's Online   1 Member, 0 Anonymous, 778 Guests (See full list)
