woofer wire size
ham4864
What size speaker wire is appropriate for 1 incriminator audio running 1000 watts?
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Depends on the length of half the run of the circuit.
This should get you in the ballpark
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
The biggest that fits
Why waste money when it won't change a thing?
i use knu 12g wich i think is plenty. you will have a hard time when wiring 2 or more with that wire
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
i'm talking about in side the box itself.
2009 bmw 5 series
Head Unit Stock
2009 bmw 5 series
Head Unit Stock
sorry for the double net acting stupid.
2009 bmw 5 series
Head Unit Stock
The chart above tells you what gauge wire to use.
You get how many amps are being given to the driver.
Then measure how long the run from the positive to negative speaker terminal is. Then half that number.
For example take my design, the total wire run will be 80".
80/2=40
40/12= 3.33'
My amplifier is fused for 90 amps so I know it shouldn't be putting out much more than that, but to be on the safe side lets wire for 100 amps.
100 is equal to 1200 watts.
So we need to find 100amps and 3.33 feet on the chart.
Found it and I need 8 AWG wire for that long of a run.
Assuming you are wired to 1 ohm, 12ga ofc should be perfect. Thicker wouldn't hurt, but I definitely wouldn't go any thinner
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
