CleanSierra's build log Fosgate Regular cab!!!
CleanSierra
So the blowthrough is on hold for now since I'm not sure I'm going to keep the truck. My last setup was an isobaric box for a couple of cheap 12s and they dug low and sounded great. I've been itching to get these Fosgates in the truck one way or another so I am making a box for a single first. If I like it, I MAY run these things isobaric too.
I'm trying to get this done before a comp on Sunday. I've got the main box made. I haven't routed the sub hole or the holes for the ports either. This will be ported at 35 Hz with twin 4" PVC ports fired at the B-pillar. If you guys haven't seen, the subs are old school Fosgate goodness. They are the 4" coiled Punch Power series, circa 1998-2000.
Bottom of enclosure and back wall:
Stepped back wall:
Shell done:
This amp rack will be sort of frenched into the baffle behind the driver's seat.
I had to scrap that specific amp rack. I'm a little bummed because it looks good, really good. I had a brain fart and didn't realize I didn't have the width on the baffle for 30" of amp :(
I did bust the router out and cut port holes sub hole and mounted sub:
Twin 4 inchers
dasalottaport!
Low Fs and fair amount of peak to peak with a 35 Hz tune. You can never have too much port ;) I will be flaring that piece you see on top of the port with a 45 degree round over. I'm just needing to glue the box and redo the amp positioning :D
Looks hella good. That is going to love the lows, those subs have an fs in the low 20's right? Damn I wish I could hear this.
Fs on a stock sub is 20 Hz, but these have been reconed obviously and I don't know what the Fs on these(as they currently sit) are.
I had an old Fosgate Power HX2 12" for a while, and I loved that thing. It had a crazy amount of throw in general, but even more so playing low stuff. Those woofers should love that box.
P.S. Nice router work!
1993 Suburban
6 Crossfire XT3 15s
Crossfire XS-16k
Crossfire mids & highs and amps
65ah Cmax bank
Iraggi 320a and Mechman 300a
  • Who's Online   0 Members, 0 Anonymous, 1838 Guests (See full list)
