Deven Parent Posted September 8, 2013 Report Posted September 8, 2013 How it currently is, How I want it to be, When it comes from the ipad, this is what the wire looks like. Then from there, it goes into a 20 foot RCA cable and would connect to my adapter in the picture, then go to the amps. My BIG question is, WILL this work good? I've hooked it up on one of my bass amps and one channel on the mids and highs and it worked good, what would make this not work if It was perm. I was also thinking I could use the CC-1 to set the frequencies on the amps so I don't need a crossover, right? I don't want my subs to play anything above 125hz, and my mids and highs will play anything above 125hz. Does that sound good? My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
soffhands Posted September 8, 2013 Report Posted September 8, 2013 i would run the ipad into a preamp or a electronic crossover that way your not using a spliter i dont know what the voltage out of a ipad is i am guessing its low compared to a deck spliting them would lower the rca voltage even more . look for a preamp eq with built in crossover or a electronic crossover one or more sets of rca coming in and 2 or more sets of rca coming out to your amps
CleanSierra Posted September 8, 2013 Report Posted September 8, 2013 Uhhhh, you don't want your suns to play anything below 125 Hz?!!?! Why are you using subs at all for if you don't want bass? Im not the one you want to try to troll. Just a fyi for you.
sprkn_ranger Posted September 8, 2013 Report Posted September 8, 2013 Use this...it's what sound man car audio does for their iPad installs. http://highresolutiontechnologies.com/istreamer-12v Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Deven Parent Posted September 8, 2013 Author Report Posted September 8, 2013 LMAO. I meant I don't want them playing anything above 125. My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
Deven Parent Posted September 8, 2013 Author Report Posted September 8, 2013 ( was a double post ) My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
Deven Parent Posted September 8, 2013 Author Report Posted September 8, 2013 That thing is about 200$.... o.o My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
Deven Parent Posted September 8, 2013 Author Report Posted September 8, 2013 Thinking of a way around 200$. As meade does and shows in the video, the iPad puts out about .9 volts, but he's doing just what I want to do, and he says it's okay. It made sense to me, but I'm just asking again what's different and how could this affect me? http://www.youtube.com/watch?v=_HJOTtpgelE 6:30 or so. My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/ My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo Had an amazing time bro! Die hard Meade fan! -- My System -- 2001 Hyundai Tiburon -- (1) Rockford Fosgate 1500.1bdCP (1) Rockford Fosgate 360.3 (1) Pioneer GM-D9500F (1) Optima Yellow Top D34/78 (2) Pioneer TS-W3002D - 1000W RMS 12's (1) iPhone 5s - 32gb White (1) iPad Mini - 16gb Black ( 24/7 Headunit ) -- Wanted Upgrades -- (2) SP4 (15's or 18's) (1) BC5500 (1) Mechman 320 amp Alt (4) Optima Yellow Top D34/78 (1) Big 3 Upgrade Kit Fix my other T1500.1bdcp
john253a Posted September 8, 2013 Report Posted September 8, 2013 Idd still run it through an eq So you can split the signal without the loss of quality. To a 2.1ch signal
