Help with picking second battery
So I think im finally ready to run a second battery. Currently, I'm running a mechman 240a alt with an xs d3400. The only amp in the car is a aq2200. Big 3 done and all that good stuff. Now that that's all out of the way so no one will have to ask, let's get to it.
Would this be ok to mix with my current battery and also what is the safest way to wire it up?
http://www.remybattery.com/mobile/deka-intimidator/8a31dtm-agm-battery.aspx
Any other battery suggestions besides the obvious ( being xs). Just trying not to spend that much on a battery again when I really don't think it's needed for my application.
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
I guess you a Stinger SPV 70. Nathan from XS-Power stated longer time ago, that only Stinger batt´s are comparable with XS-batt´s.
I link you the Ebay-site http://www.ebay.com/sch/i.html?_odkw=Stinger+battery&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XStinger+SPV+70&_nkw=Stinger+SPV+70&_sacat=0, here is the Stinger from SE 30 $ lower than on there own site, there is another offer on Ebay 0,99 ccent´s cheaper than SE-Ebay.
The spec´s are a little higher than on the Intimidator batt, price is the same.
"in the abundance of water, the fool is thirsty" Bob Marley
Do you guys think this stinger battery should be enough for what im using, or should I get something bigger?
Mechman 240a alt
That deka would be enough, as long as the batteries are all agm, you should be fine.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Why you guess the Deka if he can get for the same money a stronger Stinger.
Just out of curiousity how low do you drop? That electrical seems decent im just curious i dont know alot about of electrical
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
  • Who's Online   0 Members, 0 Anonymous, 1933 Guests (See full list)
