apgiusti26 Posted September 8, 2013 Report Posted September 8, 2013 Hey All, new member to the site, long time enthusiast. I had a question regarding the big 3 upgrade on my car. It's a Lexus is300 and the stock wiring from the alternator and battery power and ground are already pretty beefy (I believe 4 awg). If this is the case, is it worth the trouble to add another wire over the stock runs, and if so, would I want to go with something thicker than 4 awg? The stock alternator is 100 amps, and I have an optima yellow top up front and a rear stinger 600 agm battery. The charging system hovers around 13.5 right now. Thanks for the input!
thefourth Posted September 8, 2013 Report Posted September 8, 2013 The thing with electrical is you can never have enough. If you plan on doing the big 3 use 0 gauge if possible. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
RooTxBeeR Posted September 8, 2013 Report Posted September 8, 2013 Well this is what you do. You figure out what your needs are, then meet them. If the power you wish to run in your car can run efficiently with 4awg wire, then leave it. If not, and your system you want to install is going to have a bigger current draw than what the stock can handle, then add on. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Tarball Posted September 8, 2013 Report Posted September 8, 2013 If you are an enthusiast do yourself a favor. Big 3 in 1/0 OFC. Do it right the first time and you never have to revisit. Depending on your system goals you may need a bigger alt. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
EricDoody95 Posted September 11, 2013 Report Posted September 11, 2013 its always worth it my friend, you can never get enough of it. if i could fit it on the bolt, id have 3 runs of 0g lol. 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
