Meen Green Audio spl build
its a 97 suburban k 1500 with the 5.7l 350
standard dash kit pioneer avh6300bt deck and the cd player delete kit
i use it to haul shit all over the place after school... i work for a construction company as a grunt so it sees a lot of abuse
i have the focal access 6.5 inch 2 way components this is how the front is set up
this is how the rear doors are set up
Build Log
1996 chevy suburban
2 zv4 15
kenwood excelon mids and tweeters
kenwood excelon deck
mevhman 370
3 batts all different
mechman avmb II
2 inch squat
33 inch muds
straight pipes
kixker zx series 4ch
sundown amps
memphis 0 gauge
soon to be fu audio c pillar wall
gonna go pick up a 4 channel amp tomorrow and im thinking power acoustic for now???? what do you guys think yes or no :shrug:
Build Log
1996 chevy suburban
2 zv4 15
mevhman 370
mechman avmb II
2 inch squat
33 inch muds
straight pipes
sundown amps
memphis 0 gauge
While your box looks nice those 45s are eating up a lot of internal volume for no reason. I hate the 45s everywhere crap. You also should look into at least a double front baffle and some bracing. I bet that thing will flex alot.
Ditch the factory air box under the hood. You'll be amazed at how much space opens up when done. Get a cheap short ram intake and have at it.
if you haul crap all the time I feel bad for that box finish. You spent alot of time making it look nice. Make sure you protect it.
You can fit dual batts under the hood. Shouldnt have to do any in the back for 2500 watts or so.
box looks alot better than some of my first ones.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I really hope this isn't any sort of wire
this \/
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
this \/
that is a wire but not for power it is a wire for winch controls and lights and other crap its a bunch of wires in heat shrink and they are all from the previous owner i have disconected them but have yet to pull it out. my 0 gauge db wire runs through the firewall with a firewall bushing or grommet, whatever you want to call it
Build Log
1996 chevy suburban
2 zv4 15
mevhman 370
mechman avmb II
2 inch squat
33 inch muds
straight pipes
sundown amps
memphis 0 gauge
got the amps hooked up to my test bench and they look and sound good
Build Log
1996 chevy suburban
2 zv4 15
mevhman 370
mechman avmb II
2 inch squat
33 inch muds
straight pipes
sundown amps
memphis 0 gauge
and as for power runs how many do you think i should run from batts and alternator for clean and continuous power to all amps. i ordered a mechman 300 amp and im gonna get 2 matching batts because of my ocd. how would you guys run your power and grounds?
Build Log
1996 chevy suburban
2 zv4 15
mevhman 370
mechman avmb II
2 inch squat
33 inch muds
straight pipes
sundown amps
memphis 0 gauge
Good luck with the build man, box looks good, only thing i would recommend is maybe cleaning up those wires and make them look a little bit cleaner. Especially if you plan on doing this for customers in the future. They wont want to see wires ran everywhere, but thats all i would suggest.
if your looking for big, something ive had luck with is sundown audio and digital design, they might not be something you've heard of, but they get the job done, thats for sure.
