dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 I ordered them though you I think your cody Johnson aren't you? Quote
CJ18 Posted September 11, 2013 Report Posted September 11, 2013 Yep. Let me go back and look at your invoices. Quote
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 if it helps I ordered my 2nd level 3 15 on august 26th I think and the 1st one in like july or june I don't remember Quote
CJ18 Posted September 11, 2013 Report Posted September 11, 2013 Nothing varies on your invoices. If you can post pictures of them I can see if I can tell what is different. Both should be built with the same suspension. 2 medium spiders. Quote
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 I post pics if I knew how like umm what button do I press to attach one ive got in on my computer right now Quote
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 and @ CJ pictures of the subs like the cone or them actually out of the box because right now there in the box (not the shipping box but the actually ported box lol) Quote
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 @SGunnem if I twist the one set of positive and negative wires from 1 sub and twist them with the other set of wires from the other sub and hook it into 1 pos and neg amp terminal should it fix anything? Quote
SnowDrifter Posted September 11, 2013 Report Posted September 11, 2013 Do you have a multi meter? Verify your ohm load at the amp Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 @SGunnem if I twist the one set of positive and negative wires from 1 sub and twist them with the other set of wires from the other sub and hook it into 1 pos and neg amp terminal should it fix anything? it might but that is not the right way to wire subs and will be parasitic to your amp just wire them to 2ohms til you can get a bigger amp hmm I might have to try that lets just hope they didn't mess up my other level 3 Quote
dylan117 Posted September 11, 2013 Author Report Posted September 11, 2013 Here i posted a video of it watch this: Quote
