SnowDrifter Posted September 12, 2013 Report Share Posted September 12, 2013 What's your voltage look like if you measure it before the fuse? Stick it on the pre-fuse set screw on the fuse holder ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 I have no clue how those numbers got to my DMM...the amp wouldn't even power on at 6 volts would it?! No idea guys...it literally worked fine when I first got it onto my box, then once the excursion started it started to cut out...then went to shit...maybe I was just getting bad reads..but it has all been fine exactly how it is, just since I put it on the Zv4 box... 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
bassrace Posted September 12, 2013 Report Share Posted September 12, 2013 What about the sub wires have you checked those? 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 Yeah the sub wires I took out and secured today just to be sure, after the amp started acting up. 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
SnowDrifter Posted September 12, 2013 Report Share Posted September 12, 2013 Does your DMM have pointy probes? You can poke them through the insulation on the wires to get a good reading. Almost like you are giving the wire a "shot" ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 Positive run came unsoldered from ring terminal that was connected to the battery post...but I don't get it, cause it was still touching and had a connection...about to fix that bitch. 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 One second and I'll let you know how it changes... 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
THEKINGsBACK Posted September 12, 2013 Report Share Posted September 12, 2013 Your welcome he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick: Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 Fuck yeah that did it, but my question is how the hell did my solder come undone, and why did it only happen after I got my Zv4?...hmmm. Thanks guys, you saved me a few days without bass, I woulda been hurtin without it. 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
N9neMillahhh Posted September 12, 2013 Author Report Share Posted September 12, 2013 Thanks fellas, if there is something inside of the amp though, I'll know for sure. Lol 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX Link to comment Share on other sites More sharing options...
