boricuoso Posted September 12, 2013 Report Share Posted September 12, 2013 'm running 2 2500 brutus elites. Have 0 gauge running to the back but the wires going in & out of the amps are 4 gauge . Shouldn't they be 0 gauge as well? Head unit: Pioneer DEH-P5200 HD Amps: 2 Hifonics BE 2500(Brutus Elite) 1 Hifonics BRX 1200.4(Brutus) Subs: 2 ORION HCCA 15's at 1 ohm Mids: 2 Alpine SPS-609 ,2 Alpine SPG-69C3 , 2 Alpine SPR-50C Highs: 2 Pyramid 3" TW67 Super Titanium tweeters , 2 Falcon SDS500 horns EQ: Clarion EQS746 Alt: 220amp Batts: 1 optima yellow under the hood , 2 XS POWER D3100's in the back Wire: Big 3 upgrade 0gauge all thru Fuses: Stinger 300amp Box enclosure: FATBOX USA Link to comment Share on other sites More sharing options...
BobbyG2 Posted September 12, 2013 Report Share Posted September 12, 2013 4 gauge is typically rated for around 80 amps. Which works out to around 800watts. 0 gauge is typically rated for around 250 amps, which works out to around 2500 watts. Unless you're running three 4 gauge wires to each amp, you need to upgrade the wire. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
hazestorm23 Posted September 13, 2013 Report Share Posted September 13, 2013 So 0 gauge to the back then distribution. Block with 4 gauge to amps right? You should definitely be using all 0 gauge Link to comment Share on other sites More sharing options...
