jandsaudio Posted September 13, 2013 Report Posted September 13, 2013 Question for a friend at work Setup: Type R 10 dual 4 ohm sub. Just one. Kicker zx 750.1 amp. Believe parallel. And a 5 farrad cap. All 4 gauge wire. Gets a thumping noise when changing songs, saying its a 'reverb' type deal. Anybody have any suggestions?
89capricebass Posted September 13, 2013 Report Posted September 13, 2013 Try a new set of rca's and see if it goes away Car: 2000 Ford Focus 4 door HU: Kenwood KDC-X395 Front Highs: stock Back Mids: Stock Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz) Amp:Audiopipe APSM 1500 mini Wiring: KnuKoncepts Kolossus 4awg
Rich Schenk Posted September 13, 2013 Report Posted September 13, 2013 Check your grounds one could be loose. And double check rcas. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
SnowDrifter Posted September 13, 2013 Report Posted September 13, 2013 Only when changing songs? What head unit? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
masterbusa2 Posted September 14, 2013 Report Posted September 14, 2013 At a guess it only does this when changing songs, and sources? I had this same problem on my Power acoustik radio ended up being rca grounding issue inside radio/amp, A good very simple trick to try is Strip you some speaker wire and wrap it around multiple times around each rca terminal making sure not to get it in the hole! (lol) then groudn it to the radio chassis and do teh same for the amp, worked for me! always worth a try considering it costs nothing lol
