Why Am I Not Getting Full Potential
How are your subs positioned? Subs up port back, or Subs back port back? Ive noticed in my Jeep I was louder and sounded better with port and subs back.
You'll jump up a few more dB's if you add some more power. Small box + high tune + loads of power typically = best scores.
So a smaller box, higher tuneing would be louder than a resonalble size box, high tuneing and lots of power? Thats what Ive had the best results with. Smaller boxes seem like they were being sufficated. Weird to explain.
I know that that head unit thing is the main issue....and I have it sub up port back. It sounds great so I'm happy with the positioning, and will see soon how loud it REALLY can get
A vitrolic, megalomaniacal sadistic psychopath.
Well It seams that you have good box postioning, well built box, good tuneing, correct settings on your head unit could be resrtricting your amps and subs. Thats what it does seem like.
actually that helps a ton. It confirms everything I was thinking so I definitely should get way louder soon!! Also since I will be able to lower my gains I can probably give my subs more power as well! I originally thought that was a bass boost which is why I didn't use it....
thats why it helps to be on a forum like this so we can clear things up and get everyone louder and even more annoying to the car next to us :lol:
i noticed by ear what seems like another 1-2db when i reset the amp, i was sending gobs of dirty power before, im really impressed with the re se's since they took my negligence for so long
you will be louder, and im guessing u can gain more than me cause u got 18's, mine were 12's
and i was more comfortable playing at full tilt knowing my gain was set so much lower
what u should pay attention to is the change in sound to, cause mine just seemed to breath more on lower notes and it almost smoothed the transitions between notes more since all notes were more evenly powered without distortion
you'll are crazy, use a dmm
on a Alpine IVA-D310 CD / DVD for my friend with:
2 18" fi ssds 12cuft@32hz
hifonics 2000d
stinger1700(2)
0 gauge
200a alt
with a dmm only until sub # at 15 did i see anything near 2v
it is not clipping, call alpine, when i did, they said that like jvc, the sub # needs to be all the way to 15 for full voltage
pioneer and sony's sub number is a bass boost at a specified frequency, alpine and jvc are level/voltage adjusters
(keep in mind this is what i've been told by each companies tech dept. when i was using their headunits for a system setup. I do this everytime i have a new headunit i havent used since you'd never know)
This is how i blew my RE Audio amp, i set the sub setting too low, then to compensate set the gains to high, which sent some crappy signals to my subs till they couldnt take it, now, with my jvc kd-shx8500 sub setting @ 12 instead of 0 like i thought it should be, it sounds a lot better/cleaner and the gain went from being set at 3/4 to 1/4!!
so we have it set at
volume 22 since it sounds bad after that (62% total volume only! :angry: )
sub at 15
and MXE at cc3
hope this helps
I have a JVC and keep mine at -6 at all times and compete like that
Your volume at 22 only should tell you that your gain is to high right there.....you dont wanna max out at vol 22(barely over half allowable setting) from gain being to high......that sounding bad after 22 is clipping...turn your gain down and give the sub a chance to get louder progressively with volume
2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
No alpine decks are notorious for clipping at round 23 so they should be set to 22.... 23 is 2/3 max volume which is where you would normally set gain to anyway
hifonics 2000d
stinger1700(2)
0 gauge
200a alt
sub at 15
and MXE at cc3
hope this helps
Yup Yup my alpines set the same
volume 22 (not 3/4...lol)
bass 0
sub 15 (it doesn't clip)
With subs moved forward(to allow more breathing at the port) and new tuning at +15 ....results = holy shit balls .... hahaha I also used a good dmm which goes into the thousandths place for finest of tuning, and set it to 1450 wrms this time...
edit: also the sq improved quite a bit... the subs kick way harder, to the point that it is hard to breathe when they do, and sounds such as bass guitar seem to allow the "plucked string" sound to come in better...overall fix rating :10/10
  • Who's Online   0 Members, 0 Anonymous, 3369 Guests (See full list)
