aq 3500 fusing Help
I've been looking but i can't find the answer, do i put two 380 for both inputs on the amp or just two 190 amp fuses?
hmm. do you have spare batteries in your trunk? if so i would run two sets of power and 2 sets of negative to the amp. and i would fuse each power to the amp at a 380 fuse. if thats wrong somsone correct me. but i would thin to run 2 380 fuses to each power and not 2 190
two 190 amp fuses.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
I used 2 200s for mine.. I never search for a 190 amp ANL fuse tho either! It's a hell of an amp!
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
two 190 amp fuses.
hmm is there a reason why you only want 2 190 or 2 200's? what if 1 fails it is still going to be getting somekind of power, i believe that amp , both the pos and batt terminals are connected togther inside. from what ive heard you CAN run that amp off of only 1 side of power and ground inputs.
From what I understand you can run a duel input amp with 1 set of power and ground but it is not suggested. With both its getting the proper power it needs and only using one the amp is trying to pull to much power from a single run of wire thus will cause things to go boom. (just what I have been understanding.)
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
You fuse to protect wire, not the equipment. And it's definitely not recommended to run it off one set of terminals. It stresses the board.
2 ~200A fuses. Bottom line.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Not saying they don't make them . But never seen a 190 fuse before. As said 2 200 amps fuses. And why would you use one power and ground when the amp clearly has two on the amp. Think the other one is for looks. Not being a azz . But use what the amp has on any amp. There's a reason why they are there. Great amp sir you will be happy with It I think.. Not being a butt guys and girls. I just look on amazon and the DB link fuse holders is what I'm use to house my fuses love them. Good deal for them Like 14 for one. Didn't check what shipping was. Butt still didn't find a 190 or a 40 amp one to put a 150 and a 40 amp to make a 190. SQ should sale a 190 IF they don't. Stand to be always corrected on anything I say because I'm not a know it all.
2 200 ANL fuses or no fuses.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1433 Guests (See full list)
