Will my Trunk be big Enough
Quanie
What's up everyone, so soon I'm going to be running 2 12" American Bass XFL Dual 4. The amp I'm going to be running for the subs are a AQ2200D. I love for my bass to hit the lows really hard and loud. So I was think should I keep the 2 12" AB or go for like 4 10" subs. Please if u have any great idea's that will be helpful. And its going in too a 2003 maxima. Thank u guy
I was also thinking maybe 2 15". But I'm not sure if it will sound good If Its not in the right size box. I don't have any equipment to build a box and where I live in NY I don't have the space to build one.
The 2 15s are gonna be nearly impossible to get a box in there unless you plan on building it in there and making it permanent. 2 12s would be good if you seal them from the trunk.
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
Good luck fitting a 9 cube box plus port for the 15's, I'd stick with the 12's
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
whats you max dims to get a box in and out of your trunk? or are you willing to build it inside your trunk
I was thinking to build the box inside the trunk. Can u explain alittle more about sealing it off.
let's say your box is pushed all the way up, as far as you can go, but there's gaps on the sides and the top. You'd fill those gaps(Wood, foam filler, etc. Many videos on how to, and plenty examples on this site if you look around) Sealing off helps prevent the pressure/air from bouncing off the front of your car into your trunk. So instead of some of the bass leaking into your trunk, it plays ping pong with your windshields = more bass in ya mutha f'in face.
Oh ok cool. So basically I won't have no trunk space lol. So 2 12's will be fine? Do anyone have experience with the American ball xfl line?
I have to do the measurements. I don't having any experience in building boxes or anything. But if I can I will.
  • Who's Online   0 Members, 0 Anonymous, 3402 Guests (See full list)
