advise needed for spl system... what would you do?
toolshed
I am putting a wall in my 97 ford ranger extended cab. I have 18 cubes to play with. I am planing on either 6 15 s on a flat wall with 3 cubes per sub while running two amps on them. I see everyone using the 4th orders though, so my question is would it be better to use 3 15s in a 4th order bandpass to try to get the most bass/ spl out of it? so i guess here are my questions.....
6 on a flat wall or 3 in a 4th order?
should the 6 be facing forward or would it be better to have the subs facing each other with three subs facing up and three facing down dividing three subs with a divider in the middle...
any advice would be greatly appreciated.... thanks
Id do 6 in a flat wall if you can fit it with the 4th orders unless you have someone design it that really knows what they are doing they can be hard to dial in
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
I would do 6 15's flat wall. There's a guy on here with a ranger with 2 15's in a 4th order doing big things . I'd do what you like if it was me. Both will give you good numbers done right. Love to see your build log when you do this. I have a ranger myself. What you running for gear ?? Sounds like you are about to get loud one way are the other.Do Work. Tuned end for more. Oh wellcome to the forum ...
18 cubes external? and sealed?
if not no 6 15s is fitting in that space. id look more at 6 12s or 8 10s etc.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
the amps im using are the old black earthquake 200 dhc amps, i think they are around 2500 or 3000 at 1 ohm. Not really sure about subs.. I have 10 15in. Petras hyperthrows that i had from a previous build that will probably go in until i can decide on what subs to get. it is 18 cubes internal, not including wood. all has been calcuated...
I'm not sure what your level of expertise is, but since you are asking this question i will err on the side of cautions and ask a few questions.
when you say 18 net cubes, how thick are you planning on making the walls of the box?
What where your measurements Height, width, depth
Did you take into account space for batteries, amps and such?
thanks for your input, but all of this as been taken into consideration... box is made of 3/4 in birch or sanded ply wood Haven't decided. I also always resin my boxes and this wall is going to be painted. I have been doing this since i was 16 and I'm 34. But my problem is that i have always used sealed boxes in my designs and never tied the 4th or 6th orders. while i completly understand the process and the goal, Im not familiar in how they compair spl wise to the regular sealed boxes....i worked at a shop here for along time and then got out of the business, so I'm about a decade behind in box design.... that's why i pose the question.
Lets not forget mr good ole port displacement on your volume figures
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Me just guessing, a shelf or L-port will take up around 3 cubes. Lets say with 4 subs and bracing, that leave 3.5 cubes per sub. So in a flat wall, 4 should fit perfectly. If they are older subs, that will likely want more air per sub than today's modern subs.
Question: Are these subs similar to CV Strokers with the spider on the outside and tons of throw(Xmax)?
The old CV strokers with spiders on the outside did not have alot of xmax FYI
What are your goals. A good number or loud music?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
