i already did my trunk lid with about 80 percent coverage an the a pillars all the way back to c pillars now im on the roof. my question is what would be best just put deadner in the cut out areas or to use some great stuff or some kind of non water based expanding foam to fill those areas then cover in deadner1240008_589061651157659_1561725898_n.jpg
this... also a tip ... if you can remove your trunk lid, then do so... great stuff expands like cray... and it will leak all out of the holes... so removing it and laying it down to apply great stuff would make gravity work for you... also I vote against the big gap filler... it doesn't have the same density from what I've seen... its better to just go for the red can of great stuff
Put deadener on first.
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
the way i did it was put deadener 100% overage. cut a small slit where each hole was. spray great stuff. re patch with a small piece of deadener. Let harden.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
i didn't do this with mine BUT I'll suggest it... its kind of a waste of deadener maybe... but put tiles on the big open sections of the trunk lid backside... the use strips of tiles to seal the edges where you're going to spray great stuff... then it would block/minimize leakage... also make sure your trunk is empty if you plan to do it still attached..
There is no such thing as a waste of deadener. 200% coverage ftw.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I hear that.... my "25%" coverage be like... my whole trunk looks like aluminum foil fest!
