jarod027 Posted September 27, 2013 Report Posted September 27, 2013 hey all, i am hoping you can help me with a problem i am having. I just installed a new radio, front, and rear speakers in a geo prizm. The back speakers worked when i used the original factory plugs (spliced wire to the new speaker), but the front ones did not work. So, to bypass the factory plus, I put speakers wire directly from the front speakers, to the wiring harness. However, the factory harness did not have left and right front and left/right back. So, what i did was splice the front left and back left together, and the back right, front right together. Now, I when I put the volume at a high levels, the speakers pop/crackle. I am assuming this is because i have two speakers on the same wire? if so, what else can I do
Karkov Posted September 27, 2013 Report Posted September 27, 2013 Can you possibly post a vid. of it? 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
pioneerforlife Posted September 28, 2013 Report Posted September 28, 2013 I am just guessing here but you said you have two speakers on one wire (channel). you probably wired them in parallel which (assuming they are 4 ohm speakers) dropped your impedance to 2 ohms and most head units can not run well at 2 ohms. you said the back speakers worked fine when they were on their own wire (channel) so that is why I think this. what head unit are you using and what speakers. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
