Sundown SA-12 box
Aaron Dominguez
Is buying a box your only option? Do you have the ability to build one yourself if given a design?
I want to build my own but like I said the closest place to me that sells mdf is over 2 hours away and I don't have a truck to go get it, I could use a design tho if I find some mdf, looking to tune kinda low around 30-34 hz
You can have the place you buy it make the cuts for you. You can then take the pieces home and assemble them. All you need us a design and a cut sheet
Would lowes or home depot make the cuts if I took the 2 hour trip because I prefer building 1 rather than buying a prefab
My Lowes makes simple cuts.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Both lowes and Home Depot should make the cuts for you...if you have a circular saw and a straight edge or a table saw at home, then have them cut the pieces a little larger than you need and them trim them down to the correct dimensions yourself. I've found that sometimes they aren't super careful with measurements and will be off a 1/4" sometimes.
Can any 1 give me a design for a box for the SA-12? I talked to the local audio shop but its probably gonna be pricey (guy says the wood they use can get up to $60 a sheet) I want something that will slam hard, I want it really loud but able to pick up the lows good, I have about 36" in length, 16-17" in height, and about 20-24" of depth to work with (2004 Hyundai Tiburon hatch) I appreciate every ones help on
  • Who's Online   0 Members, 0 Anonymous, 6425 Guests (See full list)
