Multiple batteries
So I am about to do another build. Personal, and I have a normal battery under the hood an an optima yellow top in the trunk with a cap. I want to do this one perfect.
Should I put the optima under my hood an buy some kinetics? Why?
Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
I personally would keep the batteries the same as much as possible. If they are too different one can drain the other. I am sure someone with more experience can help you with that or comment more. Also on a personal note I would go with XS power batteries over any other brand. This can be argued all day on brands but that's just my opinion. There is a test on youtube that had a few different batteries and why xs would be a better choice. Check it out though if your bored.
http://youtu.be/Vez1NXufGo4
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
I seen all those videos, I just couldn't remember the name and this was the first brand name that came to mind
I don't think the yellow top is for starting the vehicle I think its the red top. BUt any way if you are going to go with more bat's I would use x's but kinetic will doo. The reason why you should not use reg bat in the front and a deep cycle as a second, Is because the Reg bat in the car will charge off of the deep cycle bat and kill it after a while. this can be resolved by putting in a solenoid between bats. Please do not use capacitor as it will not help. just stick to the bats. What do you plan on using in your set up?
King dingalingIts not finished till i say so Bit@^!
yellow top are for starting the vehicle,they're made for high electrical demand applications such as car audio. I used one for 5 years in my truck on a true 1500 watt setup charging with a 220 amp STINGER alternator.It's in a closet now resting at 12.46 volts and hasn't been charged in months. The red tops are more for drag racing,offroading,etc... Either run more YT's or change over to XS Power for batts,you could possibly run XS and the YT's together as they are the same types. Both are deep cycle AGM batts. Get a HO alt as well if you don't already have one. Caps do help if your electrical is strong and it's used correctly.
what type of application are you talking about?
Are we talking about supper capacitors?
How big of a system are you going to run?
Definitely get a HO alternator and do big 3 and a big xs batt in back
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
If you are trying to do it right then START with a H.O. alternator form a reputable company...MECHMAN/DC POWER/SINGER and BIG 3 is 1/0 OFC and build from there out.
Replace your batteries with all quality AGM.
The size of your intended system will determine how many bats and how big of an alt you want to get
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I just bought an audiotechnix 1200.1 and my cap is 8ferrads also have a clarion 1410 amp for doors. Also I do have a solonoid between the 2 batts. I am going to run 2/0 wire. Big 3 will prob be with multiple runs of my 8 (it's what I have)
All wire is solid coper not cca. As for the alternator I didn't want to install a second or upgrade because of $$$ unless I notice I need it
I'm looking for cost effective. For example this is old welding cable. That's why. Was also trying to integrate the stock battery
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
