Turn down the EQ on the H.U. Like stated, you will likely want it as flat as possible. I think it would be ok if you increased a little, but not as much as you are doing. Turn the other levels down and see if that helps at all. Also if you have a "source level adjustment" like for a ipod and you turn the volume up on that it will also show distortion earlier.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Never use bass boost!!! Its you subs worst enemy . Match you source level with a dd-1 also. I think Steve has a vid or two on you tube on how to use your dd-1 for all of this.
I'll turn everything down and reset everything. I'll just order new tweeters from crescendo. My subs I just installed a few days ago. Got 4-18's Psi pf1 with high performance upgrades. I'm pushing em with 2 dc audio 2.0k's.
Sorry you had to learn the expensive way bro. Make use of this forum and you will learn an incredible amount of good knowledge and use the search function.
1. Start from scratch, eq flat, bass boost off and ipod level normal, loudness off.
2. Check the amp bass boost too on any amps, they should be off.
3. find the headunit max outut using the 0db tones. 40hz and 1k.
4. Once you have those, set the amps useing the -5db tone for mids and -10 for subs.
6. then adjust your eq curve but like i said, just cut the middle freq and leave the lows and highs no more than 0db.
The curve should only be cutting frequencies.. Don't turn on any bass boost or adjust input levels or loudness when you are done.
If it doesn't have enough bass or treble then you need either more power, more speakers or both.
You can tweak things on the eq, but just keep it below +1db, tweeters are very easy to blow and very sensitive. They need about half the power mids do to make the same power and any clipping is super bad for them beause their coils are like .5"
Eq is causing you to clip. Instead of boosting frequencies you want louder, quiet down things you want quieter. Like instead of boosting your bass and treble like that (smiley face eq) quiet down the mid range. Same thing, but nothing gets amplified above that 0db line
  • Who's Online   0 Members, 0 Anonymous, 662 Guests (See full list)
