sierra mist Posted October 5, 2013 Report Posted October 5, 2013 So I'm beyond frustrated with getting this thing in. I call myself breaking away the bracket to clear room for the mounting depth. See below: All i have is the Axxess awsc and the gmos-04 box. What other tip or trick am I missing to get this Pioneer avic 940BT in my 04 Escalade?
baron_of_bass Posted October 5, 2013 Report Posted October 5, 2013 From what I remember you're going to have to cut the bracket going vertically in the back Team Bass-Hz
sierra mist Posted October 5, 2013 Author Report Posted October 5, 2013 From what I remember you're going to have to cut the bracket going vertically in the back As in the metal bracket part?
lightfoot Posted October 5, 2013 Report Posted October 5, 2013 I have done tons of those vehicles, should be no problem getting that head unit in since you broke out all of the plastic already. One tip, the little "pocket" on the left of the head unit should pop out and at that point you can reach your hand behind the head unit and arrange your wiring.
lightfoot Posted October 5, 2013 Report Posted October 5, 2013 your aswc and the gmos 04 should fit right up under the dash behind the head unit and behind the silver brace (which btw you do not need to remove)
CleanSierra Posted October 5, 2013 Report Posted October 5, 2013 Same dash as in my 03 Sierra as well. I've had 2 different double dins in mine and fitment was never an issue. The harness, RCAs and antenna make it a pain in the butt on that right side, but the HU well fit with no modification. Im not the one you want to try to troll. Just a fyi for you.
sierra mist Posted October 5, 2013 Author Report Posted October 5, 2013 I have done tons of those vehicles, should be no problem getting that head unit in since you broke out all of the plastic already. One tip, the little "pocket" on the left of the head unit should pop out and at that point you can reach your hand behind the head unit and arrange your wiring. You mean this area?
sierra mist Posted October 5, 2013 Author Report Posted October 5, 2013 I'm stuffin and this is as close as I've got.
