g2shuck Posted October 11, 2013 Report Posted October 11, 2013 resting voltage looks fine to me. I would have to agree with the previous post and say your idle voltage is too low for the alt to excite. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
Tebo Posted October 12, 2013 Report Posted October 12, 2013 I've seen this countless times, happened to me with one of the cheaper alt companies. What I notice is that you can't have the best of both worlds unless you drop some cash on a nicer alt. seems with the cheaper companies you get a lot of high end but nothing for Low end. I'm not bashing tenny or anything but I spent a little more money on my second alt and have had zero problems high or low rpm 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Tnop Posted October 13, 2013 Author Report Posted October 13, 2013 I am also noticing my car is starting to jerk at 15 volts it was running fine for the last few months now it is acting up does any one else have this problem?
DubNDodge Posted October 13, 2013 Report Posted October 13, 2013 Is the kintek 1400 a 14v battery? Or is that only xs that labels their 14v and 16v battery 1400 and 1600? edit: never mind, it's a 12v battery '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
