2 12 isobaric 6th order complete. full power video coming.
yo n8. for sure... :D the art of jig making seems like a good one to know... there's a lil bit of slop to it. I'm not happy about it but I ran out of wood I bought two sheets and used up all of it lmno....
trc: never heard of eighth order? same as a sixth with a resonant chamber and another port... should be ill.
I got my new amp to sell with this beast so my full power vid is coming very very very soon :D keep an eye out yall :P this bitch is brutal as fuck no lie!
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
john. but doesn't that basically undo the reason for th e isobaric reason? its to double the motor force... by running one full rms power now your actually killing motor force basically you may as just make a bigger box and have them oriented normally and run two times full rms... just curious as to the reason. not trollin or talkin shit... it makes sense in one way but in another it makes little :D
currently its 500w. amp gain set at maybe 15% boost at 2 ish db and lpf at 70 with high side tuning. so I'm not asking for a lot for em really got em wired parallel at 2. no ill effects yet will tear down and inspect on Thursday to be certain.
Congrats on the box and your efforts. Here is my input/observation.
When running iso its not that you want to run 1/2 power (RMS of one driver) but you do need to cut your box volumes in half (1/2 of the volume required for a single driver) your box looks a bit on the large side to the eyeball so be careful with your power...more for that reason.
Im no super expert with is loading but I have run a pair of 10s is in a box too large (made for 12s) on close to double power...clean. They lasted a few months but then went all smokey and finally froze up. That was 4 years ago...maybe I should tear that box apart and take a look - lol
Cheers
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
yeah it is a bit on the large side so it may end up being a bad thing as far as that goes... its about 2.5 on the low side and 1.5 on the high side after port displacement. though the eight order... will be smaller for sure... I won't mind long ass ports in that one. :D basically the initial design went wrong. .. so I did what I could to correct it and I think I got everything pretty close to how it should be...
if not I'll get my next 6th better... as far and sube comfort goes :D
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
