2 12 isobaric 6th order complete. full power video coming.
so I'm going to start here where things actually start to take shape... this is with the baffle in place.
low side ports in... tuned to 25 hz with 2 4 inch ports.
high side port and the lid. high side tuned to 70hz.
one side of the low ports are flared here... took the opportunity to make sure the subs would fit properly and that everything would be good to go... then I flared the other end of the ports.
so I decided since I'm going to be using plexiglass I may want to figure out a way to hold it in. I came up with this... its not what I went with in the end but close enough
got the high ports installed in the top flared on both sides and painted on the interior side. its starting to come together rather well eh?
a little out of order but its my log so I can do that... the high side ports painted pre lid install...
the interior is partially painted and the low side ports are shot... I probably should have waited to put the port bracing in but you live and you learn
the high side intrusions from the low side are also painted...
then it was time to warm over the outside made a dress piece for the high side ports on the outside to purdy everything up and a lil bit of bondoe before I could start to spray. its gonna be a lot of pics... very lil explanation lol. this part took forever. I wanted perfection.
here's the highside port dress.
a lil bondo to make everything look like one
after a little more sanding I moved it outside to start spraying the exterior gloss white.
after hella coats and a bit of color sanding I decided to see what the trim looked like on it...
a better shot after I got it back in the garage.
you can see I wasn't quite dome with painting yet... this is about when I said fuck it and went with a roller and paint brush to finish the paint.
my final plexiglass insert cover piece drilled and routed amd ready to paint
you can see the plexi back there and I'm finishing the drilling
http://i1332.photobucket.com/albums/w610/beastly666bassboy/FB_IMG_13809596978959998_zps63476c53.jpg
taped off the parts I didn't want sprayed and gave the low side port area a little color.
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131006_215510_zps9e4e63df.jpg
took the masking off and got this shot.
I ended up with a little over spray so I decided to leave the little bit on so I could roll on another coat of paint on the top and not fuck up the work I just did.
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131006_224149_zps2aaab515.jpg
then started tearing the masking off the inside ports...
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131006_231051_zps828b1402.jpg
put the external trim on and the cover piece just about done but a shot of what the end result will be...
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131007_001119_zps56e3845a.jpg
the interior just about all pretty... just like I imagined it...
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131007_012904_zps4658be17.jpg
Hillbilly gave me the idea of mirrors... so I ran with it... the low side mirror is still there the high side one got exed because the box didn't like it and tore it loose
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131007_015845_zps0015a97a.jpg
the highside one that got exed.
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131007_020208_zps105bf5aa.jpg
the whole picture of it just about done
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131007_020139_zpsc59f8404.jpg
plexi in and I'll call her done...
http://i1332.photobucket.com/albums/w610/beastly666bassboy/20131009_124733_zps9027b4be.jpg
its ready for my back seat till I get it sold. I may as well enjoy my work right?
short video is uploading to YouTube. its underpowered in this video but I got a bigger amp coming for it.
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
here's the low power video. you can hear the mirror on the highside rattling something fierce but that same night on the way home it got broken free amd ended up plugging the low side ports up so I pulled it out . the wiring looks wack but I was waiting for farris to get their shipment of 12g in so I just kinda winged it till I could get my shit right. enjoy.
sorta hard to believe that a box o fail could turn out so well isn't it? haha... even at the low power level it still gets all my mirrors moving... I'm currently plabing a sealed trunk sixth or possible eighth order at 1.6kw so stay tuned :D
Thank God you finally made a box worth being proud of. I'm proud of YOU. I don't know how it sounds, but it's far far far better than that last box you did. Congratulations dude, I like it. It looks like TIME invested paid off for you with this build. Good job man :)
My advice is to update the old thread where you started this build log because I'm sure those guys that were watching would be happy to see it is completed
will definitely do. may just link to this one. lol... it seems kinda wasteful but I didn't feel like digging through the muck to find it :D
thank you sir... it means a lot to hear that :D it was a challenge but I enjoyed every minute of it even the times when I was like crap am I done yet? bahaha...
actually I'm sort of in love with this box... I'm pushing about 175w in series in theory from my old dual amp(yeah the one I almost started a fire with) and it gets down... I lost my rearview a while back, damn high bass tones. but yeah literally everything else is shakin at least a little bit. but at full power I'm sure I'll hate the idea of selling it. But I'm considering an eighth order for my current 2 mtx 7k's why? because why not!? lol
8th order? lol dafuq?
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
hopefully you dont take this the wrong way but you really need to work on your cuts if you plan on selling boxes. That trim piece you made has hella visible wave to it. then youve got some of your trim rounded over some of it not. exposes screw holes all around. if you are selling these things you should really take that extra step and the finish work will bring more money.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Can't wait for the new vid!
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
