So I have 4 15" JBL GT5 subs, wired in parallel. No matter what I do , I get a 1.9 to 2.0 Ohm reading on the dmm. If I am right I should be getting somewhere in the 1.0 to 1.5 ohm .
Coil 1 reads 4.2
Coil 2 reads 4.3
Coil 3 reads 4.5
Coil 4 reads 4.5
I unhooked each sub to test the coils.
I have them wired with 8ga to the amp . I had all subs hooked up when I tested the load @ the amp. And at the sub connections .
Is my math wrong ? Or am I missing something else ?
No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement )
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
1 34s (Maybe time to change brand)
4 X 15" s
!/0 @ 2/0 OFC Wiring
:morepower1: :morepower1: :morepower1: :morepower1:
ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. :) once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
How much resistance do the leads for your dmm have?
I was un aware of the leads having any resistance. the fact I used two diff meters and got the same results
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
take your leads nad set your meter to read impedence and then touch them together. What do they read. btw one batter for 4k. is not a lot of juice.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks @ n8ball2013 ... Now i feel Dumb ....... the Cheapo reads 0.07 and the Matco reads 0.04 ...... with that being said i should be in range.
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
I am running 3 more batteries for the amps. using a matco meter and then the cheapo meter
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
  • Who's Online   0 Members, 0 Anonymous, 661 Guests (See full list)
