Punch P400.2 @ 2ohm mono?
DollarBill1
I have a p400.2 and was wondering if anyone has tried running one at 2ohm mono. I will be running a Sundown SD-2 8" D4.
2009 Chevy 2500HD Crew Cab
Current Set up -
Headunit - JVC 6100BT
Mids/Highs - Sundown SA-6.5 CS x2
- 4 Crescendo pwx6.5's
- 2 Crescendo ft1's
Mids/Highs amps - 2 Sundown SAX100.4 V2
Sub amp - NS-1 V2
Alts - 2 Singer 320a 6 Phase
2 XS D4800 under the hood
2 XS D3100's in back
2 Sundown Team 18's walled
2 ohm mono as in bridged with a 2 ohm load shown to the amp?
If I understand you correctly, I wouldn't recommend it. Each channel would see 1 ohm and I don't "think" those amps are stable that low.
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Well there is no way to wire a single D4 ohm sub to achieve a final ohm load of 1 ohm, so there's no worry there. Your only option with that sub, is to run each coil on each channel @ a 4 ohm load on each channel. That amp puts out the same power anyway on so it doesn't really matter.
The specs say you can run 2 ohm x 2 or 4 ohm bridged my sub will be 2 ohm bridged.
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
Wire each coil individually one to the left and one to the right use a mono sub out from your headunit RCA
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   1 Member, 0 Anonymous, 1373 Guests (See full list)
