Will a quality RCA cable make a noticeable difference to the sound quality? If so what do you recommend?
Check out my Youtube channel www.youtube.com/user/ologiic
Not usually a noticeable difference in sound but the ends are a lot more durable usually. I like my stingers
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Absolutely, but it depends on a lot of factors.
The correct question is: Will the right "type" of RCA cable result in better sound quality.....Yep.
You can use the best cable there is but if its the wrong type then you could still be inducing noise into your system.
Check out the threads on the different types of RCA's (balanced/unbalanced), see what you need in your application and go from there.
Do you have noticeable noise now?
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
No I don't I was just wondering because I have had my cables for about a year and a half.
If you don't have noise, then you're either:
-Using the correct cables which are fighting any present noise.
-Don't have any noise to worry about so the cables are going to work regardless.
If you're happy about the sound then I doubt you'd hear a difference, unless you step into a legit SQ setup where you need a very low noise-floor.
Now, if they're somewhat resistive and they're reducing your signal voltage to your amps, then new cables could help boost your signal which would also help the amp work with less noise.......but I'm just speculating. RCA signals are very low in current so you'll probably not see much voltage drop anyway unless the cables were pretty bad.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
I love Krystal rcas by knukonceptz you could jump rope with them bitches for days and then use em it seems lol
