Ok...I have an optime red top under the hood right now and I am going to need a battery for the back.
So what I am wondewring is what kind of battery to get. should I go with another optima in the back or should I get a kinetic?
Theres only one condition tho...I only wanna spend around $200
So here are the combinations I have come up with...buy 1 optima(red or yellow top) so that I have 2 optimas, or buy 1 kinetic HC1800 and have an optima up front and a kinetic in back, or I could get 2 Kinetic HC800's and put one up front and one in back
Which would be the best to get out of these?
depending how much amperage you will be pulling, any battery in the back will be good man
I read SOME of the wall build thread you have on here, but didnt see anything about amps
Even if you throw a $69 deep cycle battery in the back, as long as its mounted so it doesnt fly around, and it hooked up right, with preferably 1 run neg, and 1 run pos, you should be fine
But what amp/amps DO you have?
I got 2 Cerwin vega 1200D amps for the subs and a Cerwin vega 400 watt 4 channel for my speakers
OPTIMA YELLOW OR 1800 NOT 800
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
POWER MASTER IS GOOD BUT A LIL OUTTA YOUR RANGE
Edited by ARMYSGT_D
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i'd go with the two HC800s if you can cop them for $200
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Alright, so ive spent alot of money and now im tryin to save as much as I can on the rest of the stuff I need....so I figured i'd either get 1 kinetic HC800 for the back or 1 HC600.
Would either one be good enough?...im kinda leanin towards the HC600 cuz it cost less and it weights less(so maybe I can save a few bucks on gas :lol: )
right now im usuing a 10 farad capacitor and its doin the trick for now... and kinetik 600 is the equivalent to a 100 farad capacitor... ull b fine with that
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
u can get a yellow top pretty cheap look around or call places they sell them rebuilt at some stores my bro inlaw was getting them for 70.00 untill the store burnt down
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
  • Who's Online   0 Members, 0 Anonymous, 1142 Guests (See full list)
