Door Panels: Starting New 02 Civic
Locate where the positive sits just right on the door. The curve will let you know how it sits. once you found it's proper location, trace the shape to the door which is covered in painters tape to trace the shape and to protect all the work you did under it.
Carefully cut out the shape, Tip come close to the line but not up to it and use the proper tools to sand down up to the line while test fitting with the piece every few minutes until it fits tight up in its place. Take your time here. This step is very important.
Now you cant carefully cut out the center hole to place the tweeter pod.
Test fit on the door to get your proper angle on the pod
mark it if you have to.
now that you know the proper angle, Its time to cut out the rest of the shape that will fill the angle up.
first i came up with this shape.
but i quickly saw that it needed more Umpf to it so i did more of a teardrop shape that curves with the piece. Will show picture later.
to fill in that area, use a very streatchy t-shirt material. Dont use fleece for this area, it will be hard to handle on such a small area and it doesnt need all that strength to keep it together. Just T-shirt or grill cloth material, very thin and stretchy. GLue it to the back side of the pod.
cut out the back and excess material . place the pod in its place. glue it in the two spots that it holds the piece. stretch the material to the edges both on front and back. Glue them to the edges and cut out the excess material.
harden the t shirt material by applying super glue all over the t-shirt material and activator to harden it. test fit on door.
NOW ALL THAT IS LEFT IS TO BODY WORK IT AND THE DOOR FOR THAT PERFECT FIT AND LOOK.
HOPE YOU ENJOYED THIS WEEKENDS UPDATE.
god damn dude, just when I think that you are getting ready to prep and paint for a finished product, you throw down more amazing work and surprise me. I love your work. Definitely subb'd
Thanks alot man. Really appreciate all the good comments and support, Makes me feel good to see everyone appreciate what i am doing and helping.
That's a great update. Looks awesome. Can you show a pic of the door with the door panel off and speakers in? Just want to see how the door panels fit over the speaker pods.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Will do, but I read this message too late, its dark outside. I will have to wait till tomorrow and then post it.
That's cool. Thanks.
80prs
DC 180 alt
HERE YOU GO.
