Kyblack76 Posted October 25, 2013 Report Posted October 25, 2013 Oh man. Much much fail here. I'm on mobile. I'll post back when I can write a book. Maybe someone can take over. But, you would use that 40 @0db to find the HU clip point. Note that number. Now, go to the 40hz@ -10db track, to set the sub amp with the HU at the noted volume. AND!!! You need to turn the volume up on the iPod if your using that shitty head phone jack. That will also introduce voltage. So it has to be up, with your deck. All settings flat, xovers opened. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
a21cuda Posted October 25, 2013 Author Report Posted October 25, 2013 Headphone jack is terrible quality. CD and USB are the best way to go. Did you set amp gain with 0db? Sorry if I missed something I set amp gain with the 0db track. BUT I have sub level on the head unit at +15 db so I thought that would basically be like using the -15 db track.
soundstream15 Posted October 25, 2013 Report Posted October 25, 2013 Thought it would be like -15? No! -15db is bad, lots of clipping. Set head unit with 40hz @0db Amp 40hz @-10db
a21cuda Posted October 25, 2013 Author Report Posted October 25, 2013 Oh? Your ONLY using the iPod? You have no deck? No, I have a kenwood excelon deck but I meant my source for music is my iphone. I don't use CDs. So I will be using the headphone jack on the deck or the sub because all of my music is on my iphone.
a21cuda Posted October 25, 2013 Author Report Posted October 25, 2013 Thought it would be like -15? No! -15db is bad, lots of clipping. Set head unit with 40hz @0db Amp 40hz @-10db So should I put the sub level on my deck at 0db and then use the -10 track, or use the -10 db track and have my sub level at +15?
Swordlordboy1234 Posted October 25, 2013 Report Posted October 25, 2013 No. The subwoofer level inside the deck on most decks needs to be maxed. My deck is +6.... Yours is +15. That's just a setting to get the highest pre out voltage for your subwoofers. Use - 0db 40hz to find the clipping point of your deck. Change tracks, go to -5db or -10db and set your gains on the click below your 0db number. Done. And yes. Don't ever use the headphone jack. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
a21cuda Posted October 25, 2013 Author Report Posted October 25, 2013 No. The subwoofer level inside the deck on most decks needs to be maxed. My deck is +6.... Yours is +15. That's just a setting to get the highest pre out voltage for your subwoofers. Use - 0db 40hz to find the clipping point of your deck. Change tracks, go to -5db or -10db and set your gains on the click below your 0db number. Done. And yes. Don't ever use the headphone jack. Okay, thanks. So can I just use the cd to set gains, or since I never listen to CDs do I need to download the test tracks onto my phone? I tried to download the test tracks that are straight off of the cd but it wouldn't let me put them on my phone.
Swordlordboy1234 Posted October 25, 2013 Report Posted October 25, 2013 Just use the CD that came with the DD1... My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
a21cuda Posted October 25, 2013 Author Report Posted October 25, 2013 Just use the CD that came with the DD1... Okay I will. I didn't know if since USB was a different source of output than cd if that meant that I had to set amp gains with a test tone off of USB.
