Sagging rear could be fixed by welding in some steel rod between two of the coils. Every set of coils in a spring you make inactive (no longer compress) you make the spring stiffer.
Sounds like a horrible idea.
It's been done before, albeit in a different fashion. Trailer shops usually carry "spring helpers" for coil springs. They're just spacers that install between the coils, and by preventing two or more sets of coils from compressing together they increase the rate of the spring.
Just throwing it out there is Steve wanted to save the cost of coilovers to get the car's rear end jacked back up.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
It aint the first time that other brand has made an appearance. You dont have to promote what works. Go to a show and see what people are running. Youll see the same brand over and over again. Its not because they are cheap. Its not because they claim to float higher. Its because they take a beating and keep on going.
Agree'd XS has proven themselves and there is no reason to question it. On the contrary I run an NSB, but guess what? I'm not a dick and don't talk shit about it. Run what you want to run. I don't care either way.
Edited by walwalka
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
This is the DGAF car - and i am about to prove it. LOL
OK the batteries DID fit end to end in the car and i probably didn't HAVE to do this. One thing i didn't want to do was have to lay over the top of my batteries and use a mirror to set the gains, xovers etc. So i decided to make life easier on myself by dropping the batts into the spare tire well. The spare tire well is round and tapered so all 8 batts won't fit......until now :D. Anyhow, remember before you give me some advice, i already know i need to make it air and water tight. With the exception of the fan system i am going to try and incorporate now that there is a big hole, it will be water tight. This ride is probably not going to hit the highway at all, let alone in the rain so it's no problem. Anyway, I already know what i am going to do. It's not done yet but i wanted to share what i did so far so here ya go.
We pushed it out of the booth and over to the other side of the shop where the lift is. Surprisingly, it rolls easy with all that weight (the woofers/wall).
Up on the lift and deciding my next move...All i do know is it involves a Sawzall. LOL
Actually, i was going to try and pound out a little area and see if could get the batts in......but a few blows and my sledge hammer went thru. Well its no going back now! :D
Follow my Tweet (Twitter)
this is just for fitment...i plan on bracing it down the middle a few times and also sheeting it with sheet metal to keep the elements away from the rack. It shouldn't hang very much lower then the well itself used to.
I don't buy my shit built, i build it myself. Thanks very much. LOL
OH YA I DGAF!
Got home and had some stuff waiting for me from SkyHigh Audio!
Some of the nicest ANL fuse blocks i have seen.
All these fuses for 3 amps.
  • Like (+1 Rep) 4
2 175a per block (for a 350a total value) .......and 3 of those pairs per each DC Audio 9.0k
Also got some Skyhigh 4ga (red and black) OFC for the smaller amp (and future projects)....as well as some 12ga OFC speaker wire.
  • Like (+1 Rep) 3
That's a good placement for batts.
keep the good work going
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
anyone interested in the entire build and not have to wade through 23 pages of talk.....click here for all the pics, no interruptions :Dhttp://www.stevemeadedesigns.com/board/topic/178103-project-dgaf-the-smdc-audio-91-tercel-4-15-lvl-5-walled-ubla-sawzall-a-big-hole-and-battery-rack-43014/
thanks!
  • Like (+1 Rep) 6
Wow. Shit just got real!
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
since the fuses are there.... please sir a quick test of the wall on the dc 9ks
there is nothing "quick" about hooking up 8 batteries to 2 amplifiers that have 9 power inputs each let alone all the other things i would have to do. He said "since the fuses are there" hahah.....like its that simple. :D
  • Like (+1 Rep) 2
  • Who's Online   0 Members, 0 Anonymous, 2776 Guests (See full list)
