a21cuda Posted October 26, 2013 Report Posted October 26, 2013 I have a Kenwood excelon KDC-X496 and I just recently installed a 12" Kicker L7 with a Kicker zx750.1. I was trying to set my gains with my dd-1 and I tried to do it without finding the max volume on the head unit, but I think I am getting robbed of some power. If I have to take the head unit out and measure it then I will, but I am trying to do it without having to pull the dash and take the head unit out. Does anybody know where the maximum unclipped volume of this deck is? Thanks.
mmets Posted October 27, 2013 Report Posted October 27, 2013 I have a DD-1 and you can find out where you clip at from your head unit through the amps. Just have to follow the instructions. I don't have them on me or I would tell you. But with that being said no one will really be able to tell you where you start to clip at from your radio. Every vehicle is different and what you have for electrical can factor in also. You may be able to get close but only you will know. http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/Pioneer DEH-80PRSPRV 8MR400-NDY (eight) PRV TW350Ti (6)Sky High 1/0 OFC, 12 gauge and 8 gaugeTM Metalworkz battery terminals 120 sqft HushmatXS Power D3100 (6)Singer 350 Amp Alt Singer 320 (2)American Bass SQL3200 JL Audio JX360/4 Crossfire XS 8K (2) DC Audio XL 15s (6)
ChevyBoy95 Posted October 27, 2013 Report Posted October 27, 2013 if it goes to 35, it either clips at 34 or 35, sometimes they dont clip at all. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
MACnonsence6 Posted October 27, 2013 Report Posted October 27, 2013 mines 35 34 is clean - i have the ddx419 I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
a21cuda Posted October 27, 2013 Author Report Posted October 27, 2013 if it goes to 35, it either clips at 34 or 35, sometimes they dont clip at all. Does this stand true even if sub level is at +15?
Guest Posted October 27, 2013 Report Posted October 27, 2013 if it goes to 35, it either clips at 34 or 35, sometimes they dont clip at all. Does this stand true even if sub level is at +15? yes. +15 is how you get the full preout voltage on the sub preout.
MACnonsence6 Posted October 27, 2013 Report Posted October 27, 2013 so if your gains set correctly you could do sub level +15 without clipping? I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Guest Posted October 27, 2013 Report Posted October 27, 2013 so if your gains set correctly you could do sub level +15 without clipping? you got it. +15 is recommended anyway.
Swordlordboy1234 Posted October 27, 2013 Report Posted October 27, 2013 I feel like I just explained all of this to OP not more then 2 days ago. And he was also claiming to have a dd1 and using it but needed help... Zzzzz Carry on My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Swordlordboy1234 Posted October 27, 2013 Report Posted October 27, 2013 Also OP. I mentioned the +15 sub level thing at least twice in your last thread. Would you like me to find it so you can re read? My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
