dog24fret Posted October 27, 2013 Report Posted October 27, 2013 My wife's 99 gmc burb's battery is at 3.5 volts dead. This batt is 5 months old when I went to charge it. The charger will go into protect mode and say light up the error light. This thing sat for a week without being started. Lights were off including dome,map,engine bay and on & on. Modrain found yet. Throw some thoughts my way for me to figure this out with please. Thank you Cowboy Escort GrAnny ThUmper The Burp
SnowDrifter Posted October 27, 2013 Report Posted October 27, 2013 Jump the battery with a good one then hook the charger up Once charged, do a parasitic drain test. If that checks out, pull the battery, load test, and see if it will hold a charge after sitting for a few days. And while you're at it, check your alternator charging voltage ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
bbeljefe Posted October 27, 2013 Report Posted October 27, 2013 DId you disconnect the battery and attempt to charge it or did you only try with it connected to the vehicle? Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
CHEVY4X4BLAZER Posted October 27, 2013 Report Posted October 27, 2013 I agree with snow, you can force feed the dead battery for a bit with a running engine and jumper cables. Then you should be able to get the charger to take over. If all else fails, Warranty? ??
dog24fret Posted October 28, 2013 Author Report Posted October 28, 2013 Sorry guys had other things going. Yes I did disconnect the battery to charge it. Tried to jump it but battery died overnight. The alt is charging at 14.6v at 87-94amps. Can't find any drains anywhere yet. I just find it very odd it would do that for no reason. Today jumped it again let it run for 20min the. Drove it for a while. Parked it 4hrs later checked it and it was back at 5 volts. I didn't try the force feed part. Hadn't heard of that before. Thank you guys for the inputs. Other than warranty what else do I look at. I've not had a batt just go bad before without something causing it. Cowboy Escort GrAnny ThUmper The Burp
SnowDrifter Posted October 28, 2013 Report Posted October 28, 2013 Don't jump the car. Pull the battery, jump the battery with a good one, hook up the charger, unhook the battery you jumped it with after an hour or two, and let the charger continue to charge the battery as normal. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jessica Posted October 28, 2013 Report Posted October 28, 2013 if it is a maintenence battery, pop the caps off and see if it has water in it. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
bbeljefe Posted October 28, 2013 Report Posted October 28, 2013 It went bad for a reason. You might not know that reason and you may never know it but, there was a reason. If it's not under warranty, replace it. For it to drop that much voltage without being connected to any potential load, it's got some shorted cells. Three of them... Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
SnowDrifter Posted October 28, 2013 Report Posted October 28, 2013 Is the battery AGM or flooded? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jessica Posted October 28, 2013 Report Posted October 28, 2013 Is the battery AGM or flooded? You sir are my hero, ask those questions man, ask away, so much advice and no one even asks what type pf battery he has. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
