music.  takes about 30 min.
You set your amps with music? Do you use a DMM or you do it all by ear? A shop hear did it like that by ear and I didn't think any one else actually did that.
I use 50hz -3db ...what's the real difference with the 0db and the -3db...the -3db tone is MUCH louder than the 0db..so if I used the 0db to set my gain, shouldn't it be higher than if it was set with the -3db?
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
do it all by ear, i break out the ac rta every once and a while.
for the most part its all the ear.
Pretty good..I've only done 1 car by ear so far and that's my friends car...Playing young jeezy Thug motivation 101...so far so good
I used to do it by ear, but my hearing is soooo messed up now that I now use 50hz tone.
(im not kidding ask steve I have real bad hearing)
Guest MegaloManiac
50hz tone on class d amps , and 1000hz tone on a/b amps
using a dmm and the equation sqroot of (impedance X Power desired)
all 0db tones, i read -3db can damage equipment if not used properely, i dont know a lot about it but i stay clear of that until i know how to use it for sure
i set mine by ear too when theres not multiple bass amps.....
when dealing with MBA (see above) i use a dmm and 50-60hz depending on how i feel.  I dont have to do that w/the new RF amps though.  Set one gain and they all follow the leader (master/slave)  it fuckin RULES im tellin you.
Follow my Tweet (Twitter)
say when you do use the tones to set the gain... do you use a -3db or 0db and why?    oh and also can you explain me the master/slave stuff? I got a t4004 on the way :D.. so all the t4004 amps(general example) that are attached to the intial t4004 will follow the same gain setting if I set this one to master and the others to slave?
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
