SMD Sunflash and mat questions for sub box
zack_e89
First, let's say that I want to put the sunflash everywhere inside my sub box and mat in the corners and seams for extra strength. I've never done this before.
1) If if have a subs up, port back design and want to strengthen the seams on the underside of my baffles, would the sunflash be able to harden? I don't think I could get all of the seams in direct sunlight.
2)What is the best mat for strength inside a box?... considering I'm using the sunflash, if that even makes a difference
97 Suburban
8 custom PSI Platform 3 18's
I'd use normal resin for doing the inside of the box.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Thanks for the replies guys. If it turns out I have to get regular resin so be it... but I really was dead-set on using the SMD stuff! If there's a will, there's a way, maybe? hahah I'm just starting my box so I have a little time to figure this out
I thought there were certain lights you can buy that would harden the sunflash?
Now that you mention it, if I remember correctly, I think Steve mentioned this in a video or something. I guess no one has used the sunflash for a box?
97 Suburban
You can use a UV light to harden it as same as the sun, you may can get that in there by hand from a small UV flashlight instead of maneuvering the box around, Search smd flash and Steve tells all about it..
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
