big 3 question
Is it ok to have both of the grounds in the same spot or does one have to be the frame, one on the engine block? Right now I have the positive from the alt to the battery positive, and battery negative to the frame but idk where to put the second ground cause I don't see a good spot on the engine block
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
The issue is, running a ground to the only the frame does not make a good connection to your alternator because there are motor mounts and various engine gaskets that can limit the conductivity between the engine and frame. I ran a ground to one of the alternator mounting bolts, is there not a stock ground to the block you can upgrade?
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
Alright Ill do it to the alt casing, i cant find a stock ground... maybe im just blind (probably)
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Saw your alt man..
sick dude..
Bro..... pure fucking sex........ Im so excited
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 894 Guests (See full list)
