XS Power
So i started seeing my amplifiers light dim so i started going to my wires amd found out i had amy fuse blown the one that comes from my front battery to feed the back one i put my multimeter and it read 10.4 volts will that mess my battery up its 3 weeks old i have it charching right now with my charger at15 amps just curious
What are you running? What size wire is the run? Are you fused at the back battery and the front battery? What size fuse blew?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
If you don't have your rear battery fuse, fuse it as well. If that 1/0 shorts out in the middle of the run, it will pop the fuse on the front battery, while your rear battery is letting havoc rip on that short. Before you know it you car will be in a ball of flames. Obviously the wire isn't shorted currently, or you wouldn't have a car. But I would try and figure out what cause it to pop in the first place.
Edited by DubinDodge
Ok thanks i think my fuse pop like a week ago i was puting a new fuse holder fot my alt to batt and i did not removed the neg bett terminal was being lazy i did se it ark then i put it back maybe thats what made the fuse pop i only have had my system for a month
  • Who's Online   0 Members, 0 Anonymous, 678 Guests (See full list)
