only 1 sub gets warm?
moegej
so how would i fix it if a coil was out of phase?
06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
One is probably out of phase
Do a pop test by taking + and - out of the amp and connect straight to ur battery
The subs should move out together the same amount, if one moves in or not as much it has a coil out of phase or if it moves the same amount as the other in an opposite direction (inward) that sub is out of phase
Why would that make one sub warm? While it may not sound good, they are both working just as hard against each other. Right?
Eclipse cd7000
This is how your subs should we wired if you want to wire at 1 ohm like your sig says.
Eclipse cd7000
OP I assume you have a multimeter to measure the impedance of the wiring and if you don't, go get one for 20 dollars at wal mart. This is a necessity to save the agony of guessing in the future. Anyhow, Check that stuff and report back.
Eclipse cd7000
When one coil is wired against. The other on the same sub what do you think is going to happen?
That sub will more less and get hot very fast
If both subs are out of phase but coils are in phase
They would more likely be getting hot at the same rate....
That's why I said both options....
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Didn't read very well. i thought u meant 2 subs wired against each other not coils. Makes sense.
Eclipse cd7000
He has them series and parallel each sub parallel and both subs in series
4ohms/2coils= 2ohmsx2subs=4ohms
Make sense?
Yea it was late as you can see, so my bad. But it would be each sub wired in series then both subs wired up in parallel. that would be the proper way for a 4ohm final load. I guess my statement at 1:00am was premature.
truthsayer
Could be a common mistake. I've done that before. Wired one sub in series and one in parallel. Well let's see what the OP says.
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Eh works both ways LOL but I agree with cars could be somethin as simple and common as wiring wrong due to distraction or being tired hell I've done it before...but once again cars beat me to it "let's see what the op reports back with"
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
Gotta be first man. Lol it's my stupid ego
  • Who's Online   0 Members, 0 Anonymous, 5740 Guests (See full list)
