dereileak Posted November 4, 2013 Report Share Posted November 4, 2013 (edited) So I have a d3400 here that was leaking around the seams earlier last winter and slowed in the spring. Now it seems to be bubbling out liquid around the top and making a squealing noise and it seems to have cracked the casing iteseld, idk if its from pressure or what, but I have never dropped this battery, and it is located in a very secure place so it doesnt move around and is held in nice and tight. This battery see's no more then 14.3v for charging and is setup with a mechman 220 amp alt. All 2/0 gauge wiring, it had started leaking earlier this year but was holding the voltage fine, was told pretty much to keep running it, but I had the option of sending it in, I decided to just run it as it was working alright. Now it has gotten a lot worse and seems to be going all over. Its 34 months old, so 2 months from the warrenty being up, hoping Nathan will chime in, im more then willing to ship it in for warranty. The battery has fans blowing on it as it goes through the amps then the battery, ill post some pictures of how my amp rack is currently setup, I havnt updated my Build log for awhile so you will get to see some new work that hasn't been posted also Battery was part of the 2010 Group Sale buy in December, so 34 months ago. I do still have the original Receipt also! From Today November 4th (Didnt Push on it at all, this was just what it was doing) Back In April 3 - Kicker 650.4 amps mounted in the tire wheel, along with a cooling system, speaker junction, fusing, and battery tray With the top piece it holds it so it doesnt move at all, I have more room then how the stock setup was for a trunk and all my mid/high equipment installed A Lot better and space saving this this old amp rack with the old tire rack not even being used! Edited November 4, 2013 by dereileak Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
truthsayer Posted November 4, 2013 Report Share Posted November 4, 2013 Hurry up and send in for the warranty. Quote truthsayer Link to comment Share on other sites More sharing options...
Miguels Posted November 4, 2013 Report Share Posted November 4, 2013 cool little setup you got going on there Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
dereileak Posted November 4, 2013 Author Report Share Posted November 4, 2013 cool little setup you got going on there Thanks, ill get my build log updated with everything that had to be done, took tons of pictures, im thinking this battery just needs to be sent in and should be replaced under warrenty. Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
03 Xtreme Fosgate Posted November 4, 2013 Report Share Posted November 4, 2013 (edited) call them first thing in the morning and get an RA#,you'll more than likely get it handled faster than waiting for someone from XS to see this. My 3400 made a hissing noise one night after I had been driving,I'm starting to wonder if there's a problem with the D3400's and heat. I have a battery wrap on mine to keep the heat down but it was on it when the battery was hissing so IDK.. I try to check mine often because of that,my D1200 in the back has had no problems though. Nice setup btw.. I'm wondering how much space between and how you mounted those amps but I'll see it in your BL. Edited November 4, 2013 by 03 Xtreme Fosgate Quote BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild Link to comment Share on other sites More sharing options...
carshateme Posted November 4, 2013 Report Share Posted November 4, 2013 That really is a nice idea...think I'll use it for my car Quote New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center] Link to comment Share on other sites More sharing options...
dereileak Posted November 4, 2013 Author Report Share Posted November 4, 2013 call them first thing in the morning and get an RA#,you'll more than likely get it handled faster than waiting for someone from XS to see this. My 3400 made a hissing noise one night after I had been driving,I'm starting to wonder if there's a problem with the D3400's and heat. I have a battery wrap on mine to keep the heat down but it was on it when the battery was hissing so IDK.. I try to check mine often because of that,my D1200 in the back has had no problems though. Nice setup btw.. I'm wondering how much space between and how you mounted those amps but I'll see it in your BL. The d3400 was up front in the engine bay originally, but it never got hot, its pretty far from the main engine heat. The Amps have about a little less then half an inch between them, before the fans they would get very hot and shut off after around 30 mins of full tilt, but now with those fans they stay nice and cool even full tilt for over an hour or more, you can feel the air through it really well, havnt had them shut off once after making the fan system, the middle fan does around 130 Cubic ft per minute ha ha, and has a lot of static pressure, pulls in fresh air from behind the rear seat area Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
dereileak Posted November 4, 2013 Author Report Share Posted November 4, 2013 That really is a nice idea...think I'll use it for my car Here are some more pics, the main piece is a donut that bolts to where the tire goes, the amps fit perfect on that you need cooling though, otherwise it gets hot as hell in there One 2/0 is directly from the alt stud, the other is from the front d3100 battery, both fused to that center point, the battery hooks to that middle stud, and another fuse goes to the main sub amp from there so the battery is totally protected with fuses Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
Miguels Posted November 4, 2013 Report Share Posted November 4, 2013 it went from being a battery thread to being a build log lol 3 Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
dereileak Posted November 4, 2013 Author Report Share Posted November 4, 2013 it went from being a battery thread to being a build log lol yea, ha ha, well its there to show that the battery is secure, it looks to have cracked, im guessing from the pressure it built up, I just emailed Nathan too, I need to update my build log, these are all new pics Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
