rockFord_Expedition Posted November 6, 2013 Report Share Posted November 6, 2013 Your wiring is ummm bad. All that copper exposed eeeeek A suggestion if I may OP. Not knocking you, just trying to be of some help..... I am sure you see N8's comment and say you cant help it because of the angle on the inputs of the amp. He makes a good point, he isn't being a dick. What I would do to fix it without making any drastic changes would be to drill holes in your amp rack so you can bring the wires to the amp inputs at a more straight in angle. That would accomplish a few things... Exposed copper is a safety issue. Big time. Plus it opens the door for corrosion. Potentially increase surface area of contact between amp and wire = better performance and a cooler running amp It just looks better with less wire showing Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 Your wiring is ummm bad. All that copper exposed eeeeek yeah i did the best i can i need 4g to 0g reducers but its hard to get them for the hifonics amp cause the angled terminals Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 I had this exact issue a while back, and i bet its your maxxsonic amp cutting out. For me it was my cheap re audio amp cutting out. it was both amps that did it and also it hasnt done it since yesterday and ive driven a good bit. Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 Your wiring is ummm bad. All that copper exposed eeeeek A suggestion if I may OP. Not knocking you, just trying to be of some help..... I am sure you see N8's comment and say you cant help it because of the angle on the inputs of the amp. He makes a good point, he isn't being a dick. What I would do to fix it without making any drastic changes would be to drill holes in your amp rack so you can bring the wires to the amp inputs at a more straight in angle. That would accomplish a few things... Exposed copper is a safety issue. Big time. Plus it opens the door for corrosion. Potentially increase surface area of contact between amp and wire = better performance and a cooler running amp It just looks better with less wire showing easier said than done i have the amp mounted to a piece of mdf thans mounted to the sub box there isnt enough room to do that unless i did alot of work and im not even sure how long im gonna have that hifonics amp tbh. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 6, 2013 Report Share Posted November 6, 2013 are only 1/2 the channels being used on the 4channel amp? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 are only 1/2 the channels being used on the 4channel amp? yeah, im wanting to get some pwx 8s for the other 2 terminals Link to comment Share on other sites More sharing options...
rockFord_Expedition Posted November 6, 2013 Report Share Posted November 6, 2013 Your wiring is ummm bad. All that copper exposed eeeeek A suggestion if I may OP. Not knocking you, just trying to be of some help..... I am sure you see N8's comment and say you cant help it because of the angle on the inputs of the amp. He makes a good point, he isn't being a dick. What I would do to fix it without making any drastic changes would be to drill holes in your amp rack so you can bring the wires to the amp inputs at a more straight in angle. That would accomplish a few things... Exposed copper is a safety issue. Big time. Plus it opens the door for corrosion. Potentially increase surface area of contact between amp and wire = better performance and a cooler running amp It just looks better with less wire showing easier said than done i have the amp mounted to a piece of mdf thans mounted to the sub box there isnt enough room to do that unless i did alot of work and im not even sure how long im gonna have that hifonics amp tbh. You're right, easier said than done. But then again, most things are. At the end of the day its your ride and your situation which has no bearing on me, just trying to help however I can. My suggestions would involve some work on your end, no doubt; but isn't that part of the fun of our hobby? In the pics it looks like there is already some space between the MDF piece that the amps are mounted to and the sub box, but sometimes pics can be deceiving. If there is already some space there, it wouldn't be that much more work to increase the spacing. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 Your wiring is ummm bad. All that copper exposed eeeeek A suggestion if I may OP. Not knocking you, just trying to be of some help..... I am sure you see N8's comment and say you cant help it because of the angle on the inputs of the amp. He makes a good point, he isn't being a dick. What I would do to fix it without making any drastic changes would be to drill holes in your amp rack so you can bring the wires to the amp inputs at a more straight in angle. That would accomplish a few things... Exposed copper is a safety issue. Big time. Plus it opens the door for corrosion. Potentially increase surface area of contact between amp and wire = better performance and a cooler running amp It just looks better with less wire showing easier said than done i have the amp mounted to a piece of mdf thans mounted to the sub box there isnt enough room to do that unless i did alot of work and im not even sure how long im gonna have that hifonics amp tbh. You're right, easier said than done. But then again, most things are. At the end of the day its your ride and your situation which has no bearing on me, just trying to help however I can. My suggestions would involve some work on your end, no doubt; but isn't that part of the fun of our hobby? In the pics it looks like there is already some space between the MDF piece that the amps are mounted to and the sub box, but sometimes pics can be deceiving. If there is already some space there, it wouldn't be that much more work to increase the spacing. yeah you're right im kinda feeling like a change in my system is needed im just waiting for my life right now to settle down i got alot of stuff coming up. but after all that im hopping to upgrade everything. Link to comment Share on other sites More sharing options...
Soccerballzs Posted November 6, 2013 Report Share Posted November 6, 2013 How many batteries do you have? http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/ Link to comment Share on other sites More sharing options...
Blake Farrar Posted November 6, 2013 Author Report Share Posted November 6, 2013 How many batteries do you have? i only have 1 stock batt Link to comment Share on other sites More sharing options...
