BassDragon Posted November 5, 2013 Report Posted November 5, 2013 So I'm a beginner in car audio and I'm looking for a system build. It's going to be a daily system, but I'm wanting it to be louder than others. The others are friends of mine - one is running 2 Polk 12"s on 1500watts, and the other has it in with a shop owner and is getting 2 PowerBass 3XL 12"s on 3kwatts. I have a '93 Toyota Tercel, with not so big trunk space. I've looked at Soundqubed, Fi, Obsidian, etc. but I'm not sure what I should go with. My budget is $1000 MAX, and that's for subs, amp, and box (and maybe wiring, I have some but not much). If you need anything else, just ask. Thanks 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
dfoland93 Posted November 5, 2013 Report Posted November 5, 2013 Sundown SA series 2 12s (if they can fit) on a crescendo or if thats too much a Hifonics. Great first set up The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
nocturnalrites101 Posted November 5, 2013 Report Posted November 5, 2013 Two Dc audio level 3 12s or 15s if you have them room. Off a Dc 2k. there having a big sale right now .
Trayten Posted November 5, 2013 Report Posted November 5, 2013 DC is a great way to go if it ends up being affordable for your budget.. Or sundown is good too like the first guy said. Vehicle: 1988 Cadillac Brougham Pioneer DEH-X9500BHS Head Unit Custom box built by me (designed by forum member g2shuck) (1) DC XL 15 (2) SQ q1-1200d (2) Crescendo PWX-6's. (more to come someday.)
BassDragon Posted November 6, 2013 Author Report Posted November 6, 2013 I've looked at the SA's too, I'll go check out the DC's and see what I can do. It'll be about a month before I get all the money too. 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
Soccerballzs Posted November 6, 2013 Report Posted November 6, 2013 Spend it on electrical first batteries, wire, fusing. Maybe do just 1 sub and buy a cheaper amp for start. RE Audio Sex V2 sub and Re Audio ZtX 3000.1. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Slinky Posted November 6, 2013 Report Posted November 6, 2013 SoundQubed. They just came out with some new subs that are a hella good deal for the power they can take. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
BassDragon Posted November 6, 2013 Author Report Posted November 6, 2013 What about the 2 12's or 1 15 debate? Should I stick with two 12's or run a high powered 15? Any comments on that? 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k
nocturnalrites101 Posted November 6, 2013 Report Posted November 6, 2013 Normally im all about higher powered efficient subs rather the multiple subs. However in this case id suggest to twos 12s. Reason being down the road should you decide to upgrade them , you can keep the same box. Do a direct drop add a bigger amp and are good to go. There also easier to control and less likely to have an issue. Once you start to get into high powered subs upgrading them does get you as huge of gains, and to get gains it becomes expensive fast. If your new to it all the chances of hurting something go up. This way you have an ease into car audio and have future expandability.
walwalka Posted November 6, 2013 Report Posted November 6, 2013 You could pick up a couple of the Audio Technix AT800.1d's while they are clearanced. They would net you between 2000 and 2400w rms clean at 14.4v http://www.ebay.com/itm/Audio-Technix-800-1-amp-amplifier-800w-RMS-2000w-MAX-Class-D-1-ohm-stable-/111053236151?pt=Car_Amplifiers&hash=item19db49e7b7 Then you could get a couple XFL 12's and strap them on the amps http://www.carstereogiant.com/product-p/pair-xfl12.htm That would leave you with $250 left for everything else you would need. It would be pretty loud, I don't think you'll have enough left in the budget for electrical though. 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
