engine noise
Ok so I'm having an issue with engine noise. I have a highs amp and the rcas are not near the power wire. Ground is connected straight to battery in back. The batteries are ground straight to frame. I am use 4 gauge wire and nothing is loose. The hu is a pioneer deg-80prs. Have heard pioneer is bad about engine noise. What else can I do?
could try grounding your rcs's to the headunit.
06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
Ground the rcas in back of the HU
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
cheap fix, apply toroidal noise choke filter. Inline with power line before head unit. will block alt, engine and plug noise.
truthsayer
Free fix ground your head unit to the frame
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
did you read the link I provided you?
Eclipse cd7000
  • Who's Online   0 Members, 0 Anonymous, 2819 Guests (See full list)
