Slammed Dodge Challenger Sundown/CT Sounds Build
I have the same amp running a sq 12 sub. Anyway it's very important to get your gain set correctly. Also with mine it made a huge difference setting the lpf and subsonic filter . I own a dd-1 and cc-1 and that was one of the best investments I have made. Everything sounds a lot better.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Flipping the sub over means you are supposed to flip polarity. Our you can use the phase angle on the amp to do the same thing. You need to have it set on 180 IF you have the positive on your amp wired to the positive on the voice coils, and the negative on the amp hooked to the negative on the voice coils. Or set the phase angle on 0 and just switch the wires at the amp. You don't have to if you don't want to, but the sub needs to go in and out in the opposite direction than if mounted normally, so you switch the polarity to achieve this. But if it sounds ok wired normally, then wire it however you want. It won't hurt the sub
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
I've ran inverted before and suggest reversing the polarity
simple to do
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
What difference does flipping the polarity make on an inverted sub? Isn't the sub seeing the same voltage/overall load either way? Sorry for the confusion but I'm genuinely interested.
It determines the direction of movement of the cone, it basically goes the opposite direction than what it would normally in the sense of in or out excursion
Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King
Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620
Fucking love Alan you goddamned fucking super nerd lol
When Alan uses big words I don't understand
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room.
I missed Alan.
RIP 5/29/15 - I love you son.
Instead of pushing out, then pulling in, etc etc etc, after flipping the polarity, it would pull in, then push out etc etc etc.
It makes the cone move opposite of if it were wired normally.
It's hard to explain.
Wired normally the sub pushes out of the box, then pulls in, pushes out, etc etc.
To have the cone on an inverted sub physically move in the same direction as a normally mounted/wired sub, you flip the polarity. So the sub is upside down, and the polarity reversed, the cone moves "in", toward the magnet, but in orientation to the box, the cone is actually pushing out of the box, then the sub pushes "out" but the sub is pushing into the box. So it's resulting in the same "out, in, out, in" as the normally mounted sub.
I hope this makes sense
I have run one sub inverted and ran it both reversed and normal and heard really no difference. Not louder inverted, not louder inverted with reversed its pretty much all the same. Only thing I noticed is that with the sun inverted it makes the box bigger and changes tuning slightly. Just my experience with one sub. It does look pretty cool if you have a big ass motor sticking out of your box. I actually flipped mine from inverted to normal mounting yesterday. The only thing I noticed is that the metal drum beats sounded cleaner.
80prs
DC 180 alt
Supposedly it can cancel out frequencies with midbass drivers. Idk. I'm no expert. There's lots of info online about it. A lot of people say they don't notice a difference.
I love the look of those sa's inverted. Looks sick. That must bring quite the smile to your face every time you turn around and see that.
