Slammed Dodge Challenger Sundown/CT Sounds Build
hah nice. Im already wanting to build a system with either another 1400 or a bigger ct sounds with another 2 8s in a three chamber single reflex bandpass box but thats a tad bit out of my league at the moment haha
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
got these blue LED strips in the mail for under $4 on ebay. They'll go above the subs mounted to the sealed enclosure. Im debating how i want to wire it up… I'm thinking ill tap them into the remote wire of the amp to come on when the amp does?
Thoughts?
  • XS Power D3400
Build log:
TEAM GOAT
From what I have read you should use a relay then I am sure it would be fine. Not 100%sure though.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Im not all that tech savvy when it comes to what relays and resistors and whatnot are needed. I suppose i should thoroughly research first
  • XS Power D3400
Build log:
TEAM GOAT
Ya me either. Did some reading but not enough yet.
80prs
DC 180 alt
Yes a regular 4 pin would work.
The 30 pin will be your constant hot(+), the 87 will be your led hot(+), then bring your amp remote wire(+) to either the 85 or 86, and ground(-) the other. So remote(+) to 85 and ground(-) 86 or vice versa
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
You won't need any resistors. Those strips are made to run on 12v. Those are just short versions of what I'm wiring in my ports to pulse to the beat.
