need help with remote start on silverado
remote start wont start my truck.
2007 Chevy Silverado Classic Single Cab
Dash Unit:Pioneer DEH-6400BT
Amps:Alpine MRX-M240
Alpine MRX-F30
Speakers:Alpine Type S 5.25 coaxialx and 6.5 components
Subwoofers:(4) Alpine Type R 10"
Box:Quad hole fiberglass subbox
Battery:Dual Battery Setup
(2) Kinetik HC1800Power:
DB Electrical250 Amp Alternator
Wiring:KnuKonceptz Kolossus Fleks Kable 0 GaugeKnuKonceptz KCA 4 Gauge
Big Three: KnuKonceptz Kolossus Fleks Kable 0 Gauge<p>
so here is what i installed an Avital 5103 security system. i have everything installed right, all the wires for the remote start harness are installed... the neutral safety switch input is grounded, tach meter is connected to the back of the instrument panel, and brake shutdown input is connected to the brake pedal harness. my truck is a 2007 silverado classic work truck. so i converted my truck from manual windows and locks to power ones. i know on some trucks with factory locks and windows need an immobilizer bypass but my truck didnt come with any of that so im guessing i wouldnt need it. i can hear the control unit starting the remote start but nothing happends... is there anyone that has had this problem on a work truck?
Alpine MRX-F30
Security light flashing on the dash when you remote start it?
Static drops are my bag.
If your check engine light is on it won't start
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
will it start if the key is in the ignition cylinder? if so then theres your problem. try it out and see if itll start.
2000 tahoe
orion hcca 15.4
kicker zx2500
2 JL 300/4s
infinity and kicker mids/highs
KHC1400 in back, stock upfront
dont ask about my HU
clarion EQ
kicker/fosgate rcas
  • 4 weeks later...
Idata link alca should fix the problem and if you hard wire it you should only need power ground remote start status ignition and a data wire on the obd port I think those are all the wires been a while since I hard wired one but sonic should have it its not cheap but its flawless and lasts a long time
