So im building a box into the trunk. Top will be mdf and will fill the entire top of the trunk. Im going to use the trunk as the enclosure. Looking for recomindations on a good cheap filler between the mdf and fenderwells and gaps. I was gonna fiber glass the whole trunk.. but started wondering if there was a cheaoer filler that hardens... thinking like bondo or a puddy that I can fill with that hardens. Expanding foam I will use deep back in wells decided im just dynomatting the floor. so how to fill sides is the main concern.
Good Luck!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Im sure tons of guys have done this. When u need every inch of airspace build a box / trunk space ans seal it up.
I let others join in on this. Big job. What are you running and how many subs? Have you ever done this before?
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Ive never had to I have always had enough trunk space. Im squeezing 6 12s in my trunk and need every inch. Worst case scenario I will just fiberglass the pockets.
so basically 6 12s in an infinite baffle setup?uym..............
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so how are you calculating air space?
You have no option but to fiberglass it.
I think you are in over your head on this. Where are your woofers going to be mounted and firing?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Really dude over my head... really. Ive been installing for 21 years. I ask a simple question of a good filler hoping someone says yes (bla bla bla) works perfect and you figure the worst. Awesome. And p.s. for the really goofy hard to caculate air spaces use foam packing peanuts and then fill them into a 1cu ft box to figure out what your airspace is
ok have fun all star. If you've been doing this for 21 years you should know youre only option is to use fiberglass. or concrete. youd also probably know better than to try and jam 6 12s int he trunk
considering no one knows you and you have 31 posts and you're asking questions like this I have to asusme you have no idea what you are doing.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 873 Guests (See full list)
