4th order Trunk hair tricks on less then 2k.
watching this for sure, primarily because it is similar to my plans for my stratus, same subs, but rest of equipment is different, be awesome to see how it turns out, i probably wont be able to get my build started till tax time sadly. i also know very little about 4th orders, been learning as i go with some advice from singer to start with
looking good. I was going to run similar in my car, but my battery is in the wheel well, and there si very little room to work with, it sucks. they do have terminals under the hood for jumping the battery if need be, but i didnt know if i could use those to do runs to my trunk or not, so i left it alone, with my power one run is fine for now til i figure something else out
Nice gear, can't wait to see this.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
finished the box today and go the bitch in....
think i busted a nut getting that thing in the trunk
big thanks to a friend robert kelly for letting me use his shop to work at and helping the box. ( also big thanks to braxton )
1398724_10200728970138248_675655331_o.jp
1452369_10200728964258101_210521169_n.jp
1456068_10200728964178099_740245567_n.jp
1459802_10200728969178224_1116484928_n.j
port... front black and bare wood areas in cabin will be covered with fur
bracing in ported area. also the port will screw into the 2x4's to stop any port movement.
1404781_10200728965538133_509254242_o.jp
and shes done...
NOW GETTING IT INTO THE CAR..... after a couple overs of hammering and cutting and busting balls we got it in... lets just say that bitch aint coming out...
where you can see the bare wood is where more of the carpet fur will go
good bye trunk.
tuned to 42hz. real world testing revealed an actual tuning of 37-39 hertz with the sealed resonance being just about the same as the port tuning.
so for all you that understand 4th order at the tuning...... yea its going to murder the lows.
braxton helping out
o yea and lunch break went and got some diabetes.... 3 doubles and like 8 singles 3 large fries and cokes between the 3 of us :rofl2:
  • Who's Online   1 Member, 0 Anonymous, 1125 Guests (See full list)
