Alouie Posted November 15, 2013 Author Report Posted November 15, 2013 I've got paperwork on it with the name brand, specifications and all that but I have yet to find it. I have had it about a year.
Junior Russell Posted November 15, 2013 Report Posted November 15, 2013 A less than reputable place. Ebay. theres part of your answer right there imo youd be better of with a stock alt than any ebay alt http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
MrSkippyJ Posted November 15, 2013 Report Posted November 15, 2013 This is all for 1k watts? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Guest Posted November 15, 2013 Report Posted November 15, 2013 my two eBay alts were trash. literally useless for powering a vehicle. good for a paperweight though. I don't like 0 idle output and voltage fluctuations between 12 and 16 volts while playing music. they both charged almost a whole volt lower than my stock one while cold
finkster Posted November 15, 2013 Report Posted November 15, 2013 Jeez my head hurts 4 gauge CCA is not good enough for that amp, period. Try grounding straight to your alt case instead of the block. And jesus christ guys, he does not need a second battery and has nothing to do with his voltage drop. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Guest Posted November 15, 2013 Report Posted November 15, 2013 five bucks says the amp ratings on the spec paper you got are all cold numbers, with idle being like 900 engine rpm or something
RMac18 Posted November 15, 2013 Report Posted November 15, 2013 Kolossus Fleks Kable 1/0 Red Power /Ground Wire. It's 100% copper and $4 a foot. I want 100% copper but can anyone tell me of a cheaper wire out there? Can't go wrong with Knu, however if you want cheaper wire you won't be disappointed in then check out sky high here on the forums. You'll be pleased with either wire.
Alouie Posted November 15, 2013 Author Report Posted November 15, 2013 Well I can't say that it will hold up to the specs on the paperwork that came with it but it dose out perform my stock one by a long shot. I guess I should take it to a alt shop and have them test it.
finkster Posted November 15, 2013 Report Posted November 15, 2013 You upgraded all this stuff but skimped on the wiring of the amp....which is the biggest strain on your whole car's electrical system. They made that amp to accept 4 gauge OFC not CCA. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Alouie Posted November 15, 2013 Author Report Posted November 15, 2013 No I used the wire that was already run by the previous owner of the truck. I intend to get 0 gauge 100% copper and a rockford 10 fared capacitor. Just haven't made it that far yet. It is 4 gauge and the biggest the amp would except was 4 gauge so I thought it would work fine till I got the other amp an 2 more 10's. I guess I was wrong.
